WinZip 12.1 Professional build 8497
[img][Image: winzip.jpg][/img]
WinZip 12.1 Professional build 8497 (english)
What's New in WinZip 12.1?
WinZip® 12.1, released in May 2009, introduces the new extended Zip file (.zipx), the next step in the evolution of the Zip file format. Additionally, the Zip and E-Mail functions have been enhanced to in WinZip 12.1 to allow users to take advantage of the image resize feature in WinZip.
Description:
* Introduction of the new .zipx file extension. By using advanced compression methods to create Zipx files, WinZip 12.1 creates WinZip's smallest Zip files to date.
* Ability to resize images being sent during Zip and E-Mail functions. Users can quickly and easily resize images during the zip operation without altering the original in any way.
Best of all, if you're a registered user of any previous version of WinZip, you can upgrade to WinZip 12.1 for 50% off the regular list price by visiting our Upgrade Page.
If you are a registered user of WinZip 12, you can receive the WinZip 12.1 update free. Just download the update at: h**p://www.winzip.com/downwz.htm
Zipx Files Deliver Advanced Compression
.Zipx files
WinZip 12.1 introduces the new extended Zip file (.zipx), the next step in the evolution of the Zip file format. By using the most recent compression methods to create .Zipx files, WinZip 12.1 creates WinZip's smallest Zip files to date. The new .zipx file extension also makes it easier to share highly compressed files with others by making it clear that the file was created using an advanced compression method and that WinZip 12.1 or another compatible compression utility is required to open the file. Of course users can also still create “Legacy Zip 2.0” compressed files with WinZip 12.1 (resulting in a .zip file extension) by changing the compression method on a case by case basis or by changing the default compression method.
Photo Compression, Management and Sharing
Resize images on the fly
Additionally, the Zip and E-Mail functions have been enhanced in WinZip 12.1 to allow users to take advantage of the image resize feature in WinZip. Users can quickly and easily resize images in a zipped attachment without altering the original in any way. Resizing images is useful when the recipient does not need the full quality or size of the original. Resizing images before compressing them can substantially reduce the attachment size, reduce upload and download times for your e-mails, and help ensure that you don’t exceed e-mail attachment size limitations.
.exe
keygen
[-] The following 13 users say Thank You to verongskey for this post:
  • aslam, aslam, Grunf, Grunf, beta, beta, timosi™, timosi™, levanduy, levanduy, psiglos, shaqee, ska51
Winzip 12.1 Pro (8519)
Latest Build as of July 1, 2009.
[Image: winzip.jpg]
[Image: downloadqvl.gif]
[-] The following 5 users say Thank You to verongskey for this post:
  • rendel_©, rendel_©, struceng, struceng, ska51
I just uninstalled the 8497 version and installed the current version;8519. No need to even run the keygen, as long as you had the earlier version installed!
Proud Member of Best Civil Engineering Forum since May 2009
Dear Staad & Friends
Can you upload for me at other links except " ifile.it".
Thanks in Advance
michael.
WinZip 12.1 Build 8519 (16/06/09)
[Image: f7iinn3a7zwf9zj0n9s.jpg]
WinZip® is the most trusted way to work with compressed files. No other compression utility is as easy-to-use or offers the comprehensive and productivity-enhancing approach that has made WinZip the gold standard for file-compression tools. With the new WinZip 12, you can quickly and securely zip and unzip files to conserve storage space, speed up e-mail transmission, and reduce download times. State-of-the-art file compression, strong AES encryption, compatibility with more compression formats, and new intuitive photo compression, make WinZip 12 the complete compression and archiving solution.
Building on the favorite features of a worldwide base of several million users, WinZip 12 adds new features for image compression and management, support for new compression methods, improved compression performance, support for additional archive formats, and more. Users can work faster, smarter, and safer.
Key Features WinZip 12.1 Build 8519 :
* New! Photo Compression compresses JPEG files by 20 to 25%
* New! Send Selected Files from a Zip file by email or to a new Zip file
* New! Resize Photos from a Zip file when sending by email or to a new Zip file
* Explorer View displays image thumbnails for easy browsing
* New! Zip from Camera Wizard with Auto-Rotate to quickly transfer, rotate and compress photos from supported cameras yes
* New! Rotate, Resize, and View full sized images directly from a Zip file
Compression Performance and Archive Compatibility
* New! LZMA compression for better performance on most files
* New! Photo Compression for JPEG files with no loss of photo quality or data integrity
* "Best" compression chooses compression method based on file type
* New! Open and Extract 7Z, IMG, and ISO files
* Open and Extract from RAR, BZ2, CAB, LHA and other archive files
* Create Zip (legacy and advanced) and LHA files
* Create and Read Zip files larger than 4GB
Built-in E-Mail, FTP, and CD/DVD Burning
* New! Zip and E-Mail Selected Files from an existing Zip file
* Quickly Create and Send Zip files with One-Click "Zip & E-Mail"
* Use Send To and send new and existing Zip files as e-mail attachments
* New! Zip and FTP Upload Selected Files from an existing Zip file
* FTP Upload new and existing Zip files
* Zip and Burn new and existing Zip files directly to CD and DVD
Encryption and Security
* FIPS-197 Certified AES Encryption (128- and 256-Bit)
* New! Password Policy control to set complexity requirements
* New! Encryption Method control to set or disable available encryption methods
Task Automation Capabilities
* Command Line Support (separate download)
* Predefined WinZip Jobs for data backup
* Create custom WinZip Jobs to automate routine Zip tasks
* Schedule WinZip Jobs to run automatically and unattended
* Email, FTP Upload or Burn to disk a Zip file on WinZip Job completion
* Email Log files on WinZip Job completion
Easy to Learn and Use
* New! Content-sensitive Smart View logically displays the files in a Zip file
* New! Save As, Rename, New Folder make it easier to manage Zip files
* New! Zip Properties graphically displays compression savings
* New! Encryption Column in Details View shows which files are encrypted
* Unicode support to display international characters for filenames in a Zip file
* Choice of interfaces - Wizard, Classic, Windows Shell Integration
* Split Zip File to make large Zip files manageable and fit on removable media
* Create Self-Extracting Archives with Self-Extractor Personal Edition
* CheckOut to temporarily extract Zip files and clean them up when done
System Requirements: Microsoft® Windows 2000, Windows XP, or Windows Vista®
Download Links:
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 6 users say Thank You to timosi™ for this post:
  • michaelsoe, michaelsoe, hsccindia, ska51, darkdkay, haydaroglu
Can I just post the WINZIP 14 download link here or I have to ask for permission? If not what is the Correct Procedure. Thanks!!
[-] The following 1 user says Thank You to Learner for this post:
  • haydaroglu
dear 99richard
If you want to share anything. You can be helped by me and others member. But importance: not violate the rules.
WinZIP 14.0 is only beta version so it is not perfect. We need wait until final verion. But if you want, let you go.
regard
timosi
1.Follows the rules
4.Do not spam
[-] The following 1 user says Thank You to timosi™ for this post:
  • haydaroglu
Noted and Thank you timosi. I am not sure and that is why I consult first because I don't want to violate any rules.
WinZip Pro v16.0.9715 (x86/x64) BennyP 0 1,535 01-14-2012, 08:49 AM
Winzip 16.0 Pro (9661) verongskey 1 1,941 11-28-2011, 08:14 PM
Last Post: Learner
WinZip PRO FINAL v14.5 paladin 10 5,959 10-13-2010, 09:58 AM
Last Post: paladin
Winzip 14.0 Pro (8652) verongskey 0 1,923 10-16-2009, 09:05 PM
Last Post: verongskey
