Bentley SewerCAD v8i (SELECT series 2) 08.11.02.46 (5 Days Trial)
Current time: 01-22-2018, 07:32 AM
Author: BennyP
Replies 0
Views 2411
SewerCAD V8i is an extremely powerful program for the design and analysis of gravity flow and pressure flow through pipe networks and pumping stations. The program can be run in Microstation, AutoCAD, and ArcGIS modes, giving you all the power of Microstation and AutoCAD's capabilities, or in Stand-Alone mode utilizing our own graphical interface.
SewerCAD V8i allows you to construct a graphical representation of a pipe network containing information such as pipe data, pump data, loading, and infiltration. You have a choice of conveyance elements including circular pipes, arches, boxes and more.
The gravity network is calculated using the built-in numerical model, which utilizes both the direct step and standard step gradually varied flow methods. Flow calculations are valid for both surcharged and varied flow situations, including hydraulic jumps, backwater, and drawdown curves. You also have the flexibility to mix gravity and pressure components freely, building your systems in parallel or in series as they exist in the field. Pressure elements can be controlled based on system hydraulics, turning pumps on and off due to changes in flows and pressures.
Trial
VIP see in your section how to renew the Bentley Trials.
[Image: 27986033050584793184.gif]
[-] The following 8 users say Thank You to BennyP for this post:
  • oanm2000, Dell_Brett, oitv, snakes, kiefer7, CVega, topgun45, spat
Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 8,302 09-25-2017, 07:25 PM
Last Post: Aviator
Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 4,674 09-28-2015, 09:38 PM
Last Post: joker™
RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial BennyP 9 13,345 08-23-2015, 07:24 AM
Last Post: ykhackhack
RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial BennyP 12 22,837 08-18-2015, 10:00 AM
Bentley PondPack 08.11.01.54 V8i (30 days trial and renew) BennyP 4 6,373 02-15-2015, 01:06 AM
Last Post: fayezkazi
