Thermal Effects for Steel Building or Structure
Current time: 06-22-2018, 08:08 AM
Author: shaker
Last Post: shaker
Replies 0
Views 1718
THERMAL EFFECTS FOR STEEL BUILDING OR STRUCTURE
This is spreadsheet workbook for the purpose of considering the thermal effects for a steel building or structure. Specifically, the appropriate maximum design temperature change, the change of length or stress as applicable, and the maximum building or structure length either without or between expansion joints is determined. There is also a "General Thermal Effects Calculator" which can be used to selectively determine any of the analysis parameters, as well as a temperature converter which can be used to convert from °C (Celsius) to °F (Fahrenheit).
[Image: 98994367567395599893.png]
The Spreadsheet:
The book which spreadsheet is based on:
Article listed in spreadsheet:
Many other good spreadsheets located near first link by Alex Tomanovich.
[-] The following 11 users say Thank You to shaker for this post:
  • kowheng, maad59, civilgr, Dell_Brett, salahcivil, sasan7351, hcardenas, tremonti, arceon, Umer.Aleem, malc
