changing background color
i cant see writings because of background colour of forum theme what can i do?
i am using mozilla and chrome
thanks in advance
jaffa kree
[-] The following 1 user says Thank You to ascetic19 for this post:
  • jonev
because you use classic mode, i fixed it for you.
anyone have problem goto User CP>Edit Option remove check bar of classic mode:
[Image: attachment.php?aid=499]
.jpg   1.JPG (Size: 70.47 KB / Downloads: 133)
[-] The following 9 users say Thank You to Administrator for this post:
  • ascetic19, ascetic19, Grunf, Grunf, levanduy, levanduy, jaks, jaks, jonev
How can I change the font color of the links? All links appear with yellow font on white background and are not visible.
For example:
[Image: mix4vd8094ly5gssv68q.jpg]
[-] The following 1 user says Thank You to ivanveliki for this post:
  • jonev
(10-10-2009, 02:29 PM)ivanveliki Wrote: How can I change the font color of the links? All links appear with yellow font on white background and are not visible.
For example:
i couldn`t understand where happen this problem, please post here an example .
[-] The following 1 user says Thank You to Administrator for this post:
  • jonev
For example:
I thinks that in the tag code. It limit all html link. So you can't change color font in the tag code.
Because if you can change font color in tag code, tag code will be tag quote.
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 1 user says Thank You to timosi™ for this post:
  • jonev
here is what I see in every post where "code" tag is used:
[Image: th20z8a51lh1ho5mn9os.jpg]
This happened when you did the last forum update. I googled the problem, but I couldn't find how to change the font color in "code" tag without using more complex technics.
I think the problem is in "style.css". Look at this site:
There it is said that in "style.css" the two tags "pre" and "code" may be changed
[Image: wvvqb73dzl68j6tg7omr.jpg]
[-] The following 3 users say Thank You to ivanveliki for this post:
  • timosi™, timosi™, jonev
dear vanveliki
i have no problem with code tag & links, i saw this topic that you put pic of it & i saw all text in code tag is black, see here:
[Image: mj1w3ojx8rad874hhzpu.jpg]
may be this problem is from your browser,
which browser do you use?
do other user have same problem?
  • jonev
I am using Firefox 3.5.3
Maybe the problem is in the browser. I will check to see if something pops up.
  • jonev
(10-10-2009, 07:46 PM)ivanveliki Wrote: I am using Firefox 3.5.3
Oh, dear friend
I am using firefox 3.5 and there is no problem.
regard
1.Follows the rules
4.Do not spam
[-] The following 7 users say Thank You to timosi™ for this post:
  • Dell_Brett, Dell_Brett, Administrator , Administrator , niki102, niki102, jonev
[PROBLEM] How to change the forum background color from black to other colors myplaxis 1 1,681 07-19-2015, 05:06 AM
Last Post: ykhackhack
