RAM Elelments v8i (SELECTseries 2) 10.5.0 Build 122
Current time: 06-20-2018, 04:35 PM
Author: BennyP
Last Post: joker™
Replies 3
Views 6591
This program provides unequaled flexibility for the design and analysis of different types of 2D or 3D structures containing linear members and shell elements.
The types of analysis available are: First order (Linear Analysis), Second order (P-Delta Analysis) and Dynamic (Seismic Analysis).
In addition, RAM Elements is also capable of designing hot-rolled or cold-formed steel members, wood (sawn lumber and glulam) and reinforced concrete members using the AISC 360-05 ASD, AISC 360-05 LRFD , BS 5950-00, AISI 01 ASD, AISI 01 LRFD, AS4100-98, NDS 05 ASD, ASD 05 LRFD, ACI 318-99, ACI 318-05 y BS8110-97 codes respectively. The program includes special modules for designing spread footings, combined footings, reinforced concrete columns, retaining walls, concrete walls, tilt-up walls, masonry walls, continuous beams and trusses. Additionally RAM Elements has links with RAM Connection, a revolutionary tool that allows the fast design of steel connections inside or outside RAM Elements, STAAD.Pro, the RAM Structural System and ProSteel (SDNF).
The previous medicine of struceng still working
[Image: 51436925580992551490.gif]
[Image: 50593348794835379057.gif]
For "medicine" refer to post #2 @:
Dell Brett
[-] The following 19 users say Thank You to Dell_Brett for this post:
  • haze, sonidero, oanm2000, ranasanga, aema, tremonti, valinhas, zrilek, spat, kerenski_t, mickaddy, oreslaw, bigone, malc, Octavio, adams, ting tsai huang, mgdario, xuanxo
MIRROR LINKS:
cheers
[-] The following 14 users say Thank You to l_namali for this post:
  • Dell_Brett, jcbv, llbb, malc, haze, zrilek, apiratkan, ha893459, bigone, adams, valinhas, taifur, oanm2000, narendra
HOTFILE MIRROR
No limits to creativity
[-] The following 5 users say Thank You to joker™ for this post:
  • Dell_Brett, zrilek, arceon, xuanxo, oanm2000
STAAD.Pro V8i SELECTseries 5, build 20.07.10.64 coxxxyboy 7 12,159 06-17-2015, 01:35 AM
Last Post: b.s.s
