eXpert PDF Editor Pro 6.30.460
Current time: 05-22-2018, 09:20 AM
Author: cordoba123
Last Post: cordoba123
Replies 0
Views 1566
[Image: 99218654454566614583.jpg]
eXpert PDF Editor Pro 6.30.460 | 26.96 MB
eXPert PDF Editor is the solution for viewing/printing and editing pdf documents. With eXPert PDF Editor you can view, navigate, manipulate, mark-up and save PDF files while still maintaining the integrity of the original documents..eXPert PDF editor allows full editing on pdf documents (Pro edition) with out the needs of external applications. While other editors are limited to specific pdf objects editing or aplly many kind of limitations on pdf editing expert pdf editor will allow you to modify any object with its unique WYSIWYG interface and functionaltiy.
With eXPert PDF Editor, you can significantly accelerate your review cycles using powerful commenting tools, while protecting the integrity of your source document. eXpert PDF Editor also allows you to easily insert, extract, delete and rotate, and re-order pages from multiple PDF files to produce one PDF file.
eXPert PDF Editor provides a cost effective, reliable and easy to use tool within the corporate, government, and education markets. eXPert PDF Editor is a companion application to eXPert PDF Creator and is also available as a standalone product.
[Image: 30009595941173412832.jpg]
[-] The following 6 users say Thank You to cordoba123 for this post:
  • mowafi3m, simanta, uetian19, kevin8107, isurya, dede
