Steel construction Terminal Building
Current time: 06-22-2018, 08:19 AM
Author: vati
Last Post: scorpion07
Replies 4
Views 8581
Hello to everyone.
Here are the structural drawings of a steel construction Terminal building.
[Image: 78163372784964220574.jpg]
[Image: 49816024455093141265.jpg]
______________________________________________________________________
HI
Here are the Architectural,Electrical,Plumbing,Climate control
[-] The following 31 users say Thank You to vati for this post:
  • Dell_Brett, deviationz, chigozie, ali akbar, shaqee, cmorpar, isurya, vedranius, dbanj, civilteam, mowafi3m, gacella, Mohoh77, engrasad, Vincwilson, gelbert, hmwere, pm81, ambrish, Vufor, cristi, lesgiu, wanazri, zrilek, JPx2, STRAIN, wannaspk, mvdcq, oanm2000, bigone, albani
i think the uper roof curve is not good if the roof is straight . . . if you slide the roof back to some degree it'll be ok or bend the roof other way . . . for the flow of water.
water proofing is the first point you should consider.
[-] The following 1 user says Thank You to enricoy for this post:
  • Aryan
This is one of many reasons why the uper roof is devided in several parts
[Image: 87011140035505135339.jpg]
[-] The following 2 users say Thank You to vati for this post:
  • nanescul, mikebi
Steel construction Terminal Building Mirror Link
[-] The following 8 users say Thank You to rezart for this post:
  • Grunf, techno, malc, Dell_Brett, Jackass, madforelmo, zainseiya, albani
A new link
[-] The following 8 users say Thank You to scorpion07 for this post:
  • visu, lednar_ved, Trishu999, blaze, civilgen, engrasad, pram, febo927
