Staad Plate
Current time: 10-21-2018, 10:14 AM
Author: zbizafar
Last Post: seb3k
Replies 4
Views 2249
Staad Plate
I am having problem analysis a 600 x 600 x 10 mm plate in staad. with only self wt the stress are so high. I am attaching the staad input file, please check and inform what i am doing wrong.
The plate is intended to be a chequered plate cover over underground Pit.
Staad Plate
[Image: 72248410582195005212.jpg]
I saw the model and didn,t find any problem. You have to choice which result you want. Here are some fig to explain staad plate result.
[Image: 83708703919839107980.jpg]
[Image: 44600074212933457787.jpg][Image: 06340803732022944351.jpg][Image: 51455109612719140654.jpg]
Men Build too many walls not enough bridges.
[-] The following 1 user says Thank You to triance for this post:
  • zbizafar
I have attached the absolute value from staad, i know you can check for different stresses but i can't understand how a 600 mm long plate with self wt only can have such high stress values. if you see in the model almost all stresses are very high. Maybe i am looking at it in a wrong way but i am confused.
Thanks,
I am sure many people here know the solution to the problem, please make time and reply.
Thanks
You made an error in syntax while adding self weight load
it should be:
LOAD 1 LOADTYPE None TITLE SELF WT
SELFWEIGHT Y -1
replace theese 2 lines, keep everything else the same and it works perfectly (ran it in staad2007).
deflection is about 0.02mm
[-] The following 1 user says Thank You to seb3k for this post:
  • zbizafar
