AutoCAD Civil 3D 2010
Autodesk AutoCAD CIVIL 3D 2010
32Bit
DVD 51x100 Mb
Description:
AutoCAD Civil 3D help civil engineers optimize project performance with geospatial analyses to identify the best project site, stormwater analyses for more sustainable design, quantity takeoff and dynamic earthwork calculation to optimize material usage, and 3D visualizations to better understand project impact on environment.
Rigards
>> First learn from cracked software than be licensed1 <<
[-] The following 19 users say Thank You to cod-X for this post:
  • Administrator , Administrator , kamran, kamran, oanm2000, oanm2000, Dell_Brett, Dell_Brett, schiboub, schiboub, essam2109, essam2109, Jaimechanquin, Jaimechanquin, cc4ever, u4406014, ticojuanjo, jinualex, faxel
Autodesk AutoCAD Civil 3D 2010 x86
[Image: stcqo9ddhfcskojb3hs5.jpg]
AutoCAD® Civil 3D® civil engineering software uses building information modeling (BIM) to help civil engineering project teams evaluate more what-if scenarios earlier in the design process and get transportation, land development, and environmental projects done faster and more efficiently.
AutoCAD Civil 3D helps civil engineers optimize project performance with geospatial analysis to identify the best project site, stormwater analysis for more sustainable designs, quantity takeoff and dynamic earthwork calculations to optimize material usage, and 3D visualizations to better understand project impacts on environment.
Features
AutoCAD® Civil 3D® software, the building information modeling (BIM) solution for civil engineering, helps teams design, analyze, and visualize projects more efficiently. With built-in tools for geospatial and storm water analysis, quantity takeoff, and 3D visualization, civil engineers can explore more what-if scenarios and optimize project performance. Core features and functionality of AutoCAD Civil 3D include:
* Geospatial analysis integration in conceptual design
* Surveying and coordinate systems
* Surfaces, grading, and dynamic relationships
* Building information modeling for street and highway design
* Intelligent pipes layout
* Integrated hydraulic and hydrological analysis for storm water management
* Facilitates team coordination—synchronizing design changes
* Dynamic quantity takeoff and earthwork calculations
* Styles, CAD standards, and production drafting
* Data compatibility and interoperability
* Visualization and better communication of design intent
Homepage
screenshots:
[Image: AutoCADCivil3D2010.jpg]
Kamran via HP :)
[-] The following 22 users say Thank You to kamran for this post:
  • cod-X, cod-X, oanm2000, oanm2000, essam2109, essam2109, cgedmundo, cgedmundo, Administrator , Administrator , Dell_Brett, Dell_Brett, schiboub, schiboub, timosi™, timosi™, Jaimechanquin, Jaimechanquin, mig21, jinualex, gre130, faxel
only 32 bit no 64 bit
Kamran via HP :)
[-] The following 8 users say Thank You to kamran for this post:
  • oanm2000, oanm2000, essam2109, essam2109, Jaimechanquin, Jaimechanquin, antoleg, faxel
sorry
pass:
Kamran via HP :)
[-] The following 6 users say Thank You to kamran for this post:
  • oanm2000, oanm2000, essam2109, essam2109, jinualex, faxel
(06-08-2009, 10:29 AM)dbanj Wrote: Hello guys please can i get only the crack for Civilcad 2010.I have got the sofware already.
Hi Dbanj
Downlaod the keygen for all AUTODESK products, for both 32 and 64 bit. Use the serial and product keys provided in the readme.
In the case for CIVIL 3D
serial: 666-69696969
product key: 237B1
Enjoy
Proud Member of Best Civil Engineering Forum since May 2009
[-] The following 13 users say Thank You to yakwetu for this post:
  • dbanj, dbanj, oanm2000, oanm2000, essam2109, essam2109, cristi, cristi, jopacam, antoleg, kuben, Amobin, faxel
1. Autodesk site:
System Requirements for Civil3D
Microsoft® Windows Vista® Ultimate/Business/Enterprise or Microsoft® Windows® XP SP2 or SP3. Microsoft Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3 GHz or higher with SSE2 technology
4 GB RAM – suggested /3GB switch (on 32 bit operating systems)
7 GB disk space, 2 GB free after installation
1,280 x 1,024 display with true color, 1,600 x 1,200 or greater recommended (OpenGL® accelerator with full OGL ICD support not required), 32-bit color video display adapter (true color), 128 MB or greater, Direct3D®-capable workstation-class graphics card. Multiple monitors are supported.
Microsoft® Internet Explorer® 7.0 or later.
DVD drive
2. You wrote:
so I increase it by severals ways explaining by internet but the problem is not found solutions.
I know one way only to increase the physical RAM - buy and put in the memory slot.
3. Autodesk Autocad LT forum discution:
error 1933 is a Windows Registry error that shows up during software
installation: you have a Windows Registry that is unstable, fix it before
you lose Windows.
Get a free or buy a good quality Windows Registry Cleaner tool, repair your
Windows, manually uninstall all Autodesk products, restart Windows and
reinstall.
I suppose tht it is possible to get the same error in Civl3D.
4. Microsoft site:
The /3GB switch allocates 3 GB of virtual address space to an application that uses IMAGE_FILE_LARGE_ADDRESS_AWARE in the process header. This switch allows applications to address 1 GB of additional virtual address space above 2 GB.
The virtual address space of processes and applications is still limited to 2 GB unless the /3GB switch is used in the Boot.ini file.
This is only an example, make tour boot.ini:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows XP Professional" /3GB
  • oanm2000, oanm2000, kamran, kamran, schiboub, schiboub, snakes
New links:
[-] The following 1 user says Thank You to Dell_Brett for this post:
  • u4406014
AutoCAD Civil 3D 2018 BennyP 5 3,183 04-16-2018, 04:55 AM
Autodesk AutoCAD v2010 x86 & x64 Eng (DVD-ISO) [NoPE]+AutoCAD Civil 3D 2009 kamran 1 2,755 04-20-2014, 08:31 PM
Last Post: cenlara
Portable Autocad 2010 Lite kirankumarklk 2 2,332 04-02-2013, 08:05 AM
AutoCAD Structural Detailing 2010 dancob 4 11,278 01-10-2012, 03:46 PM
Last Post: gargi
Autocad 2010 (x32) Portable BennyP 2 3,330 06-29-2011, 09:56 AM
Last Post: nik.firmann
