Bentley Rail Overhead Line V8i (SELECTseries1) 08.11.07.229 (30 days Trial)
Bentley Rail Overhead Line is an advanced computer-aided drafting and design application for the layout of
structures and wire runs used in the overhead line equipment of electrified railways and features a simplified
user interface. The command set is optimized for ease of learning and ease of use.
Bentley Rail Overhead Line is a database-driven application which stores
all the required project information in a project-oriented database. The
interface (when designing an overhead line equipment system) is
supported by the application's dialog boxes as well as by the CAD
platform's dialog and the design file.
The system is based on three parts:
 Design file
 Project database
The system reads and writes data to a locally connected database that
contains the data for a single project. The contents of that project
database can be uploaded to a centralized database. A project in the
central database (main storage area) can then be downloaded for further
maintenance into the locally connected database.
30 days Trial
[Image: 97437774018721574703.gif]
[Image: 76432014694363786915.gif]
[-] The following 6 users say Thank You to BennyP for this post:
  • mahyarov, Dell_Brett, sasan51, thinhdq2005, sructme, ssi3k
RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial BennyP 9 14,285 08-23-2015, 07:24 AM
Last Post: ykhackhack
RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial BennyP 12 24,251 08-18-2015, 10:00 AM
Bentley PondPack 08.11.01.54 V8i (30 days trial and renew) BennyP 4 6,897 02-15-2015, 01:06 AM
Last Post: fayezkazi
Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 8,805 09-09-2013, 06:23 AM
Last Post: pezhmankhan
Bentley GeoStructural Analysis 16.0 (trial) BennyP 2 3,462 08-08-2013, 12:52 PM
Last Post: 3fan
