CSI ETABS V9 - Printable Version +- Civil Engineering Association (https://forum.civilea.com) +-- Forum: Software (https://forum.civilea.com/forum-65.html) +--- Forum: Software Product (https://forum.civilea.com/forum-105.html) +---- Forum: Csi Products (https://forum.civilea.com/forum-41.html) +----- Forum: ETABS (https://forum.civilea.com/forum-177.html) +----- Thread: CSI ETABS V9 (/thread-8.html) |
RE: ETABS v9.7.1 - joker™ - 11-10-2011 Install File Code: *************************************** CSI ETABS Version 9.7.4 - joker™ - 01-31-2012 CSI ETABS Version 9.7.4 Full Size: 98 MB
ETABS MODELING • Object Based Graphical Interface • Model Templates for Most Steel & Concrete Building Systems • Models Created Using Building Terminology • Beam/Column/Brace Frame Objects • Wall/Slab/Deck Shell Objects with Internal Meshing • Story Definitions using the Concept of Similar Stories • Common Labeling of Objects between Similar Stories • Complex 2D and 3D Shear Walls Interacting with Beams & Columns • Integrated Graphical Section Designer for Complex Frame Shapes • Editing with Move, Merge, Mirror and Replicate • Accurate Dimensioning with Guidelines and Snapping • Rigid, Semi-Rigid and Flexible Floor Diaphragm Definitions • Powerful Extrusion Command for Generating Ramps • Auto Line Constraints for Mismatched Wall Meshes • Quick Draw Options for Object Creation • Draw Command for Easily Adding Openings to Floors • Support for Multiple Coordinate Systems • Powerful Grouping and Selection Options • Automatic Generation of Code Lateral Wind and Seismic Loads • Automatic-Permutation of Wind Directions and Eccentricities • Transfer of Loads from Decks/Slabs to Beams and Walls • Vertical Area Loads in Any Shape or Configuration • Cracked Properties – Property Modification Factors • Gravity, Pressure and Thermal Loading • Wind Loading on Open Structures • Sequencing Allowing Adding or Removing Objects/Loads/Supports • Buildings with Base Isolation and Inter-Story Dampers ETABS ANALYSIS • Static/Dynamic Analysis for Frame and Shear Wall Buildings (N, P) • Response Spectrum Analysis with Eigen or Ritz Vectors (N, P) • P-Delta Analysis (N, P) • Automated Center of Rigidity Calculations (N, P) • Rigid, Semi-Rigid, Multiple and Flexible Floor Diaphragms (N, P) • Frame Objects Drawn as Members – Automatically Meshed (N, P) • Automatic Meshing of Decks/Slabs for Diaphragm Analysis (N, P) • Wall/Slab/Deck Modeled with Shell, Plate or Membrane Types (N, P) • Applied Force and Ground Displacement Loading (N, P) • Seismic Acceleration or Displacement Time History Analysis (N, P) • Wind Load Forcing Functions (N, P) • Explicit Panel-Zone Deformations (N, P) • Effects of Beam-Column Partial Fixity (N, P) • Construction Sequence Loading Analysis (N) • Frame Hinges for Axial, Flexural, Shear & Torsional Behavior (N) • Nonlinear Static Pushover Analysis (N) • Viscous Dampers (N) • Base Isolators (N) • Gap Object for Structural Pounding (N) • Nonlinear Time History Analysis with the Wilson FNA Method (N) • Large Displacement Analysis (N) • Sequential Construction Analysis (N) SEQUENTIAL CONSTRUCTION (N) • Model Effects of Construction or Demolition • Specify Active Structure by Stories or Groups • Geometric Nonlinear P-Delta and Large Displacements • Sequential Construction Load Cases for Design • User Defined Loading PUSHOVER ANALYSIS (N) • FEMA 273, ATC-40 • Force-Deformation Relations for Steel & Concrete Hinges • Modal, Uniform, or User Defined Lateral Load Patterns • Capacity Spectrum Conversions • Effective Damping Calculation • Demand Spectrum Comparisons • Performance Point Calculation • Summary Reports including Plastic Hinge Deformations ETABS DESIGN • Steel Frame Design for AISC-ASD & LRFD, UBC, British, Canadian, Italian and Euro Codes • Concrete Frame Design for ACI, UBC, British, Canadian, New Zealand, Indian, Mexican and Euro Codes • Composite Beam Design for AISC-ASD & LRFD, British and Canadian • Concrete Shear Wall Design for American, British & Canadian Codes • Automated Steel Joist (K or KCS) Selection • Design for Static and Dynamic Loads • Floor Vibration Analysis with Murray Damping • Automatic Calculation of Moment Magnification Factors • Automatic Calculation of K-Factors & P-Delta Effects • Steel Frame Design Offers Automatic Member Selection • Seismic Requirements for Special Moment-Resisting Frames • Automatic Tributary-Area Live Load Reduction • Graphical Section Designer for Complex and Built-Up Shapes • Special Moment Beam Types for Steel Frames • Virtual Work Based Optimization for Lateral Deflections • Camber and Stud Requirements for Composite Beams • Grouping for Design Envelopes • Designed for Biaxial-Moment/Axial-Load Interaction • Seismic Check of Beam/Column Joints in Concrete Frames • Automated Effects of Panel-Zone Deformations on Lateral Drift • Doubler Plate and Continuity Plate Design • Seismic Design for Concentric/Eccentrically Braced Steel Frames • Display of Reinforcing for Columns, Beams and 3D Shear Walls • Shored and Un-Shored Design for Composite Beams Code: *************************************** Code: ***************************************
Code: *************************************** Code: *************************************** CSI ETABS Version 9.7.4 Full CD Size: 309 MB
Code: *************************************** RE: CSI ETABS Version 9.7.4 - joker™ - 02-03-2012 Mirror Links: ETABS V9.7.4 Full CD ZIP 309.4 MB(on site) Code: *************************************** Mirror Links: ETABS V9.7.4 StandAlone ZIP 97.51 MB(on site) Code: *************************************** RE: ETABS 9.7.2 - RazvanMelek - 07-28-2012 Size: 161 MB
Etabs 9.7.2+ Medicine( Lic Generator tested on Win 7 SP1 x86) + Getting Started Guides (Collection of several .pdf's to help you on your way )(Scanned with KIS 2010 no virus) Code: *************************************** RE: CSI ETABS Version 9.7.4 - KhaLed-S.E - 02-01-2013 CSI ETABS Version 9.7.4 Full CD Size: 309.4 MB
Code: *************************************** RE: CSI ETABS Version 9.7.4 - BennyP - 02-08-2013 CSI Etabs 9.7.4 | 315.7 mb Posted in Lavteam and grabbed by someone to other share sites. Not downloaded but the solution is the same as in our site (License generator for CSI products) and for sure grabbed from here. Anyway, we live in a global world so we all use the same sources. Code: *************************************** RE: CSI ETABS Version 9.7.4 - pezhmankhan - 04-08-2013 CSI ETABS Version 9.7.4 Full CD: *************************************** Code: *************************************** RE: CSI ETABS Version 9.7.4 - arshiakh - 04-15-2013 CSI ETABS Version 9.7.4 Standalone Code: *************************************** RE: CSI ETABS Version 9.7.4 - usmank94 - 11-30-2018 Does anyone have this setup with working crack RE: CSI ETABS Version 9.7.4 - ripach - 12-01-2018 CSI ETABS Version 9.7.4 (98.9 Mb) Code: *************************************** |
