CSI SAP2000 v14.1.0 - Printable Version +- Civil Engineering Association (https://forum.civilea.com) +-- Forum: Software (https://forum.civilea.com/forum-65.html) +--- Forum: Software Installation Problems & Bugs (https://forum.civilea.com/forum-106.html) +---- Forum: Archive Problem (https://forum.civilea.com/forum-28.html) +---- Thread: CSI SAP2000 v14.1.0 (/thread-2355.html) |
RE: CSI SAP2000 v14.1.0 - sbarwal - 10-20-2009 Can v install SAP2000 on Ubuntu (Linux) machine.... I have tried with wine software .... but :( RE: CSI SAP2000 v14.1.0 - aamir10 - 11-09-2009 PLEASE SOMEONE HELP ME THE PATCH IS ASKING FOR PASSWORD RE: CSI SAP2000 v14.1.0 - aiham_rk - 11-15-2009 did any one try to use the crack with windows 7 a friend tell me that the crack invalid in this new system RE: CSI SAP2000 v14.1.0 - struceng - 11-15-2009 @ sbarwal: Unfortunately it is impossible to run Sap2000 on Linux with any software/freeware even with the most current kernel. @ aamir10: But it is already given in post#1. Code: *************************************** @ aiham_rk: You didn't give any information about which crack was used. If you are talking about the one at post#1, then it is tested and working on both 32bit and 64bit versions of Windows 7. Regards. RE: CSI SAP2000 v14.1.0 - zaqzaq - 11-21-2009 I have a problem with Sap 2000 v14.1 in design of steel structures. I think it-s disigne wrong. Please help...... I have a model created in sap 2000 v10 an i run in sap 2000 v 14.1 and the rezults it-s different RE: CSI SAP2000 v14.1.0 - struceng - 11-21-2009 (11-21-2009, 05:17 PM)zaqzaq Wrote: I have a problem with Sap 2000 v14.1 in design of steel structures. Actually, design results are not wrong zaqzaq. When you open Sap2000 v10 model in v14, it will be converted first to v11 then to v14 model. All the new options in these versions will be taken with its default values. Also there may be improvements in the design code you have selected. It is normal to get different results. Check your v14 model's options: material properties, design preferences and especially automatically generated design combinations. Since you are new in that version, I suggest you to upload your model that is giving wrong results as you think and ask for help in the "Civil Engineering Discussion > Problems" section. As to remind, here is not the right section to ask and discuss this subject according to our forum rules. Regards. RE: CSI SAP2000 v14.1.0 - preceptor - 11-22-2009 dear members, im using struceng's patch and isi's patch same struceng's patch conclusion we can using both of them, for example, im using isi's patch,but it has already equall struceng's patch, i guess it has stealed from struceng. RE: CSI SAP2000 v14.1.0 - tam7007 - 11-25-2009 To all staff that frist i am setup sap v14.1 and crack ( From struceng ) i use Ok about 1 week ,after that this programe cannot use that show license not found Error #17 , and i try new insatall that cannot use , Plaese help me I use windows vista Thank you. RE: CSI SAP2000 v14.1.0 - xeno - 11-28-2009 can anyone help me with this problem: i can't seem to install the software...it stops at half of copying files and my pc freze after a few seconds, i can't do anything. i tried to install it several times on xp and w7 both x86 (i have both OS installed on my pc) and every time the same problem:(. have any ideas ??:-s. i realy need this program for my projects. thanks RE: CSI SAP2000 v14.1.0 - mojoomla - 02-04-2010 The medicine has a Trojan in it. Avira anit-virus detected it as TR/Agent.56832.BJ. |
